Old 05-30-2018, 03:45 PM
Lenticularis Lenticularis is offline
Question Accelerated motion
Is there a simple solution to implement accelerated motion in Vizard?
Or do I have to use the normal vizact.move function and combine it with the formula "v = a · t + v"?
Any ideas?
Old 05-30-2018, 04:22 PM
Are you moving the viewpoint or some objects? Can you describe a bit the application you are creating?
Old 05-31-2018, 07:13 AM
Lenticulariss Lenticulariss is offline
Registered User
Objects. I want to move an object (let's say a car) forward for a certain duration and with a certain average velocity. But with accelerated movement, not with constant velocity.
Example: vizact.move(0,0,6, velocity)
--> In this function I can define the direction of movement and the duration of the movement, I can also specify a certain velocity. But now I want to accelerate this movement by let's say 1 m/s^2 (so that the velocity is rising for the specified amount of time)
Old 06-01-2018, 05:38 AM
Moving an object.
Vizact.move(0,0,velocity,time) --> I can indicate a velocity and a duration of the movement. How to implement accelerated movement?
Old 06-01-2018, 04:46 PM
You could apply a force using physics or register a function with vizact.onupdate where the object's position is set each frame.
Old 06-07-2018, 11:57 AM
I tried the following code. Do you see mistakes?
def Movement():
	Object.setPosition(0,0,0)
	v0 = 0
	t = 0
	a = 1
	while t < time:
		s = v0*t + 0.5*a*t**2
		vizact.ontimer2(0.1,0,Object.setPosition,0,0,s)
		t = t+0.1
I was not really expecting it to work since it was only a "quick and dirty" solution. But I actually don't see where the problem is.
Old 06-08-2018, 07:00 AM
Never mind. Managed to do it with an even simpler solution. It is not entirely precise, but it works quite well. It isn't even shaking. Here is the code I used:
def Movement():
	v0 = 0
	t = 0
	a = 5
	while t < time:
		Object.setPosition(0,0,s)
		t = t+0.0168	#Adjustement based on processing speed of computer (lazy amateur workaround)
acceleration, motion, movement, velocity, vizact
Mismatched Translation Between Real Motion and Display amir Vizard 2 05-31-2018 08:17 AM
Motion Builder Without Live Characters? lafortuj Precision Position Tracker (PPT) 2 07-30-2015 06:21 PM
PPT Mocap and Motion Builder Connection Problem hxphan Precision Position Tracker (PPT) 3 02-22-2011 12:01 PM
an object in motion does not stay in motion? driechers Vizard 2 11-09-2010 04:51 PM
Motion Capture & CyberGloves EnvisMJ Vizard 1 10-01-2009 05:21 PM
