Old 04-26-2018, 06:51 AM
tianmoran tianmoran is offline
Unhappy Avatar animation -- change states
I want to change my avatar's states according to conditions. However, there are some problems with the codes:
def ani_change():
	female1 = viz.add('Avatars/Avatars/CC2_f001_hipoly_A1_v2.cfg')
	female1.setPosition(1,0.5,1)
	female1.setEuler(90,8,0)
	bloNo = 10
	Code = [0,1,0,1,0,1,0,1,0,1]
	for block in range(bloNo):
		female1.visible(viz.ON)
		if Code[block] == 0:
			female1.execute(8,0,0,freeze =  True)
			female1.setAnimationSpeed(8,0)
		elif Code[block] == 1:
			female1.execute(3,0,0, freeze = False)
			yield viztask.waitTime(3)
			for j in range(10):
				female1.blend(3,1-float(j/10))
				female1.blend(8,float(j/10))
				yield viztask.waitTime(float(j/2))
			yield viztask.waitTime(0.5)
			female1.state(8)
		female1.visible(viz.OFF)
		yield viztask.waitTime(5)
viztask.schedule(ani_change())
Here are the problems:
1) The avatar's states don't change;
2) The amplitude of the avatar's movement decrease across different trials. Eg. The highest point that her arm could reach is always lower than in the previous trial.
Many thanks!
aavatar, animation
Walking Animation of Avatar pradeep Vizard 1 07-03-2014 03:35 AM
Clarification on CAL3D Avatar Animation in Vizard shivanangel Vizard 2 11-22-2010 07:16 AM
Collision and avatar animation shahramy Vizard 2 10-26-2010 11:47 PM
changing between avatar states dan12345 Vizard 1 06-23-2008 01:39 PM
avatar animation problems jrodman Vizard 1 01-18-2006 09:12 AM
