Old 01-09-2018, 09:27 AM
A Wundlechner A Wundlechner is offline
Check for running SteamVR
Hello everyone,
for my program I want to use 2 different controlling scemes. One should be controlled with a gamepad and the other one is for steamvr. I want the following behaviour:
If steamvr is already running, I want to use the steamvr controlles.
If it's not running, I want to use the gamepad.
For those 2 cases I've already created 2 configfiles with vizconnect and I changed my specific code parts within the scripts. I only need to know if steamvr is already open.
I haven't found a helpfull command within the steamvr library, to check if steamvr is running. If I run the steamvr.HMD() command when steamvr is closed, it just opens steamvr.
Thanks in advance,
Andreas Wundlechner
Old 01-10-2018, 09:02 PM
Rather than checking if SteamVR is running, would it work for you to check if the controllers are connected or not in there? If so, take a look at the initInputs section of a Vive config file. That checks for whether the controllers are connected.
Old 01-11-2018, 01:03 AM
Thank you for your reply.
it also opens steamvr when I check for controllers by this command: steamvr.getControllerList()[index]
But it doesn't matter for me anymore, beause in the meantime I already found a solution for my problem. I installed the psutil library. I search with it for the running process "vrmonitor.exe". If I find the process, then steamvr is running.
controller, steamvr, vizconnect
check if fixation is on target VizMars Vizard 1 11-14-2017 10:20 PM
how to check if specified number of targets are in proximity sensor? Vaquero Vizard 8 12-27-2016 05:23 PM
Check if file exists jassel41 Vizard 2 09-27-2011 11:22 AM
Check presence of joysticks ? hotspur1 Vizard 1 05-18-2010 10:33 AM
Check if an avatar has a state "123" Josh Vizard 1 04-06-2010 01:11 PM
