Old 12-06-2017, 12:09 PM
Vishav Vishav is offline
File Handling
If i open file every time i need to write data then this error not comes but then new problem came that is infobox.remove() is not working. Adding snapshot for reference.
Source Code:
if radio1.get() == viz.DOWN:
infoBox.remove()
score=0
os.chdir(r'D:\PhD\Study-Click image for larger version
experiment_data = open(str(id) + '_experiment_data.txt','a')
feedback = viz.addText('You are doing Great!',viz.SCREEN)
.wrl File in Vizard Hitesh Vizard 2 07-02-2015 10:43 AM
Converting .blend file in .osgb or any vizard supported file Hitesh Vizard 0 07-02-2015 02:31 AM
Vizard .exe file doesn't load (Vizard 3) Saule Vizard 4 02-05-2014 07:01 AM
Interaction of vizard objects with an imported obj file sunil.nair Vizard 2 10-09-2013 03:08 PM
