Old 09-14-2017, 01:25 AM
It sounds like you're setting it up correctly in vizconnect. The quad buffered stereo will not work immediately after you apply the setting in the vizconnect GUI. You must save the config file and then run it again because quad buffered stereo needs to be initialized before the graphics window opens. Does that work for you?
Regarding changing &using multiple tools at same time through vizconnect rajnishv Vizard 7 09-08-2016 05:48 AM
Zspace display in Vizconnect JB_HP_Viz Vizard 5 06-05-2015 04:28 PM
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 06:19 AM
delete hand in vizconnect rvenegas Vizard 4 06-05-2014 11:17 PM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 10:45 AM
