Old 11-16-2005, 03:51 PM
Jerry Jerry is offline
user input problem
In the following script I want to have the user enter the name of a text file which is later read from within a called function. It works, but a yellow error marker appears at the line that calls the function and the cursor jumps to that line. This is annoying since I then have to find the place in the script where I was editing. Can you suggest a better way to do this?
filename = input('filename?')
def openfile():
global filename
file = open(filename, 'r')
openfile()
Old 11-16-2005, 04:15 PM
Try the following instead:
if viz.running():
	openfile()
This makes sure that the file is not opened when the script is being parsed within the GUI.
