Old 12-01-2016, 11:30 AM
The model units in Inspector and Vizard are in meters. It looks like the model needs to be scaled down by a factor of 1000 or 100. Most likely the original model units were in mm or cm. You can scale the model and move the geometry to the world origin in Inspector. Then save it out with the changes.
Old 12-05-2016, 07:17 AM
Patrick Patrick is offline
Thanks for the help, worked properly
So my problem is that the STL data has "wrong" parameters?
It kinda bothers me tho that i always have to scale down every STL data down to make it work properly in my World. Isnt there a possibility that the STL data comes scaled in the right way already or is that a matter of setting up the STL data?
Import viz from c++ Ciccio Vizard 4 06-07-2016 03:21 PM
reagrding closing the output window console of vizard rajnishv Precision Position Tracker (PPT) 1 04-27-2016 03:25 AM
Unable to draw EyeLink drift correction to screen chris2307 Vizard 6 08-18-2014 02:22 PM
Best way to import map data from 3ds Max v-Salik Vizard 6 04-09-2010 04:40 AM
Pick porblem with arrays shivanangel Vizard 3 08-27-2007 10:10 AM
