Old 11-17-2016, 04:23 AM
zumbay zumbay is offline
Yes, of course!
It seems I found the main reason for the frame drop: its the collideMesh() I am adding to the models.
I attached 2 images, showing the render stats for 2 versions of the same environment, once with and once without collideMesh() for each model.
Would be great if there is a way I could still be able to grab, move, and overlap this limited amount of objects.
thanks
ID:	859   Click image for larger version
winviz.exe has stopped working TarkaDahl Vizard 2 05-21-2012 03:06 AM
Winviz.exe does not "finish". (Pylab problem) migoloco Vizard 1 09-23-2010 12:42 PM
winviz.exe problem llqqff Vizard 2 07-16-2010 10:08 AM
Extending python using winviz.exe Enlil Vizard 1 08-12-2009 11:59 AM
trouble with winviz.exe bnord Vizard 4 09-21-2006 05:22 AM
