Old 07-29-2016, 12:02 PM
willpower2727 willpower2727 is offline
Question Diffuse Maps in 3ds not exporting to OSGB
I know this has been a topic a few times, but I can't figure out how to get the osgb exporter in 3ds to export my diffuse maps correctly. I've attached images of my desired export result, how it looks when rendered in 3ds, and my osgb export settings. I apologize the screen shot from Vizard is dark, but the issue is that none of my maps made it through the export process.
Any help, ideas, or directions is greatly appreciated!
I'm using 3ds MAX 2013 with Vizard 5
ID:	799   Click image for larger version
ID:	800   Click image for larger version
ID:	801   Click image for larger version
Old 07-30-2016, 06:24 AM
I'll ask one of our artists to take a look.
Old 08-01-2016, 06:43 AM
Let me know if I should attach the files, if that would be helpful
Old 08-12-2016, 02:20 PM
I found a somewhat adequate solution. I baked my diffuse maps and they show up in the osgb, however I am not perfectly in control of my mappings yet so the textures appear odd but they are there. Baking is the solution I think.
Old 09-29-2016, 02:13 PM
Hey, sorry I missed this one.
One possible cause is using a material type that the exporter can't read (e.g. VRayMtl), but it's tough to say without seeing a sample file.
If you still need a real solution to the problem, feel free to upload a small isolated sample that reproduces the problem (e.g. a single box).
The best way to send over export settings is to use the "preset" option in the bottom left of the OSG Exporter window. I've uploaded a copy of the settings that worldviz typically uses.
I also noticed in your screenshots that you had some of the optimization features checked. Most users should actually be disabling them - they're really only useful in some very specific situations, and minimally at that, and can do more harm than good if used in a model that doesn't need them.
File Type: zip wv_osg_defaults.zip (302 Bytes, 5569 views)
3ds max, osgb, osgb export
3ds max 2014 crashing on exporting to OSGB raj Vizard 1 09-16-2015 04:13 PM
Trouble Exporting OSGB Animations via Sequence Helper (3Ds Max) envi253 Vizard 1 06-05-2015 12:31 PM
Demystifying exporting light maps from 3ds Max to Vizard? dproeder Vizard 1 06-14-2013 02:34 PM
Weird colors exporting OSGB from 3DS nkinerd Vizard 2 05-09-2013 04:53 PM
3DS Max Export: automatic shader assignment for various maps emlyn Vizard 0 03-14-2008 10:29 AM
