Old 09-15-2016, 06:22 AM
M@rcello M@rcello is offline
Hy jeff and thanks to give always an answer to my doubts.
The function write is called every time that button 1 is pressed,it doesn't matter if it held down or not.
Anyway,I have found on this forum a similar post,in which you suggested to use the pencil from the tools module.
This is the code and it works:
import vizshape
import vizmat
import viztask
viz.MainView.setPosition(0,0,-40)
viz.clearcolor(viz.GRAY)
sensable=viz.add('sensable3.dle')
device=sensable.addHapticDevice()
device.workspace.setScale([10,10,10])
from tools import pencil
tool=pencil.Pencil()
pen=viz.add('art/pencil.obj')
pen.setPosition([0,0,-2])
pen.setScale([0.05,0.05,0.05])
cube=viz.add('art/box.wrl')
cube.color(0,0,0)
cube.setScale([35,20,0.1])
cube1=viz.add('art/box.wrl')
cube1.setPosition([-17.5,0,0])
cube1.setScale([1,21,0.2])
cube1.color(0,255,0)
cube2=viz.add('art/box.wrl')
cube2.color(0,255,0)
cube2.setPosition([17.5,0,0])
cube2.setScale([1,21,0.2])
cube3=viz.add('art/box.wrl')
cube3.color(0,255,0)
cube3.setPosition([0,10,0])
cube3.setScale([35,1,0.2])
cube4=viz.add('art/box.wrl')
cube4.color(0,255,0)
cube4.setPosition([0,-10,0])
cube4.setScale([35,1,0.2])
myButton = viz.addButtonLabel('Erase')
myButton.setPosition(0.5,0.1,0)
myButton.setScale(3,1,1)
count=0
def MyTask():
	while True:
		yield viztask.waitButtonDown(myButton)
		tool.clear()
viztask.schedule( MyTask())
def UpdateModel():
	line = viz.MainWindow.screenToWorld(device.getPosition())
	pen.setPosition(line.endFromDistance(40))
vizact.ontimer(0,UpdateModel)
def write(e):
	if e.button==0:
		update(tool)
		viz.link(pen,tool)
viz.callback(viz.SENSOR_DOWN_EVENT,write)
def update(tool):
	tool.draw()
tool.setUpdateFunction(update)
The problem is that when i press the button of the stylus it starts drawing the trajectory but it never ends. I am looking to implement some control so that when the button is pressed again the trajectory is not drawn, and again if i press the button for the third time the system starts again drawing the trajecotry.I hope it is clear
Suggestions?
I need something like when you enter in this function,execute and repeat it until this event happens. The problem is that with the while loop everything freeze
Need help with Phantom omni sebzim4500 Vizard 3 05-26-2016 08:05 AM
Phantom omni Vs Vizard blessonisaac Vizard 2 03-23-2011 02:25 PM
Phantom Omni Device Scripts vSuejung Vizard 1 09-17-2008 04:42 PM
Phantom Omni Demo betancourtb82 Vizard 1 10-17-2006 10:23 AM
Direct access to phantom omni data vsully Vizard 1 03-14-2006 09:44 AM
