Old 10-21-2005, 09:44 AM
pkhoosh pkhoosh is offline
Send a message via AIM to pkhoosh Send a message via Yahoo to pkhoosh
Timer event documentation
This is from the help doc
You should now see the projector light flickering on and off very slowly. It's easy to crank up the speed of the flickers. Just change the speed of the timer in the "starttimer" command. Make the "viz.starttimer " line read the following to see it flicker at 20 times a second instead of 2 times a second:
viz.starttimer(0, 0.02, viz.FOREVER)
Shouldn't the latter starttimer parameter be 0.05 instead of 0.02?
many thanks,
pete
Old 10-21-2005, 10:12 AM
You are absolutely right, thanks for bringing it to our attention. Looks like someone is a little rusty on their 5th grade math skills.
