I got a reply from the Ascension technical support:
"An Ethernet plugin is REQUIRED to talk to a MotionStar Wired, Wireless, or the 3DNavigator. If Vizard does not have an Ethernet MotionStar plugin (not the same as the serial Flock plugin) then the MotionStar Wireless system will not work. The Ethernet MotionStar products use a different protocol for data, and are not compatible." Will you please modify the code to support this? Many thanks in advance. |
| Thread Tools | |
