Old 07-28-2016, 01:03 PM
ghostx ghostx is offline
Vizconnect Display Issue
I am working on a project that I create a scene myself, and use a given config file to display it. The problem is when I follow the documentation script:
import vizconnect
viz.setMultiSample(4)
vizconnect.go('vizconnect_config.py')
It display perfectly on Christie Auto Calibration. But, it only shows white while I use my own scene.
room=viz.addChilde('room.osgb')
BTW, I can run my scene correctly on my own PC and lab's PC without the config file.
The display device is Christie Auto Calibration with 8 projectors.
My scene is built by 3ds Max and then export it into osgb format.
Thanks to anyone who can help me.
Old 07-30-2016, 03:57 AM
What is the size of the model file? When it's loaded on the PC and completely in view what do the render stats show? Press F4 twice to see the render stats with the Vizard script running. I wonder if it has something to do with running a heavier model on that system. Is it possible to disable AutoCal and run the script across all the projectors? If so, does the model show up? Also, try running it on just one or across a few projectors and see if that works.
Old 07-30-2016, 02:00 PM
Thanks for you reply, Jeff.
The size of the model file is about 180 MB.
And the render stats shows in the pic below.
I just searched the forum, only got this thread with keyword "AutoCal". Do you mind let me know how to disable AutoCal?
Because I am not in the Lab right now, I will try it tonight.
Thanks.
Old 07-31-2016, 07:46 PM
What are the graphics cards in this system? I was referring to Christie AutoCal or whatever software is being used to blend the images.
Vizconnect and MainView craigpet Vizard 2 08-27-2015 04:41 PM
Zspace display in Vizconnect JB_HP_Viz Vizard 5 06-05-2015 03:28 PM
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 05:19 AM
Duplicate HMD display on primary monitor, with eyetracking info performlabrit Vizard 3 09-19-2014 10:44 AM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 09:45 AM
