Old 07-16-2016, 04:47 AM
rajnishv rajnishv is offline
Question Regarding getting yaw, pitch, roll separately frm 'vizconnect.getEuler('trac') functn
Hi Jeff,
I need each of the euler values separately from
vizconnect.getTracker('HeadTracker').getEuler():
I have managed to get the euler values of the head tracker by the code thrugh vizconnect.
#------------------------------Vizrad Code Start---------------------------------#
def restrictRollFromHeadTracker():
headTracker=vizconnect.getTracker('dtrackheadtrack er')
eulrHeadTracker=headTracker.getEuler()
print 'the position and euler are',eulrHeadTracker
vizact.ontimer(0,restrictRollFromHeadTracker)
#------------------------------Vizrad Code End---------------------------------#
But i need each of the values 'separately' such as..yaw,pitch and roll and want to store into 3 separate variables and then want to apply on the tracker node with some different values.
I am not able to found the code or command to deal with it.
Waiting for ur reply.
Thanx & Regards!!!
Mr.Rajnish Vishwakarma
Software Developer
at
Xenium Digital Pvt. Ltd,Mumbai
(Customer of world viz)
Old 07-16-2016, 04:58 AM
The getEuler() command return a list with yaw, pitch, and roll. You can get the individual values directly:
yaw,pitch,roll = vizconnect.getTracker('HeadTracker').getEuler()
Or first save the list and then get the individual values:
ori = vizconnect.getTracker('HeadTracker').getEuler()
yaw = ori[0]
pitch = ori[1]
roll = ori[2]
Old 07-16-2016, 05:00 AM
Sorry Jeff,
To disturb you.
Thanx for the reply.
I got it when i got an error that getEuler returs a list and i managed it to store it.
Thank you for ur reply
Old 07-16-2016, 05:19 AM
Jeff,
One more query ,i want to re-apply the same yaw ,pitch to the head tracker but i have to restrict the roll value of the head tracker so that roll doesn't work using the code,but i m not able to get it:
#----------Start----------------
def restrictRollFromTracker():
headTracker=vizconnect.getTracker('headtracker')
yaww=eulrHeadTracker[0]
pitchh=eulrHeadTracker[1]
headTracker.getNode3d().setEuler([yaww,pitchh,0],viz.ABS_PARENT )
vizact.ontimer(0,restrictRollFromTracker)
But i m not able to retrict the roll value of the tracker again.Pls help.
#-----End---------------
Thanx & Regards!!!
Software Developer
at
Old 07-16-2016, 05:49 AM
In this case you don't need to get the yaw, pitch, and roll values. Just get a handle to the tracker link and use the link.setEuler operator:
trackerLink = vizconnect.getTracker('headtracker').getLink()
#Keep the incoming yaw and pitch, but zero the roll
trackerLink.setEuler([None,None,0])
The problem of tracker using via VRPN _kj_ Vizard 2 08-13-2009 01:03 AM
question about yaw, pitch, roll TunTun Vizard 2 05-23-2007 01:46 PM
