Old 07-15-2016, 06:04 AM
Whats the difference between: viz.ipd(0.06) and viz.MainWindow.ipd(0.06),i m confused on this.
In the first case the ipd value is applied to all windows while in the second case only to the main window.
Is it compulsary to use the other values such as ,fusion distance,screen distance,fov in combination with IPD.
If you're using one of the vizconnect options to setup a powerwall/CAVE or you're programming directly with the vizcave module, you don't need to specify any of these values. Vizcave does the calculations based on the wall dimensions you've provided and tracking origin relative to the walls.
If the stereo is swapped it will cause the stereo effect to look off. That can be changed in the nvidia control panel.
Temporarily cease Oculus DK2 rendering or hide display willpower2727 Vizard 5 09-07-2016 09:39 AM
question about oculus rift DK2 and oculus runtime bbb Vizard 1 01-05-2016 11:23 PM
problem with DK2 runtime 0.8 dig Vizard 2 11-16-2015 02:49 AM
Loading at runtime EnvisMJ Vizard 3 06-22-2010 04:30 PM
