Old 07-15-2016, 04:52 AM
rajnishv rajnishv is offline
Question Regarding 3D Depth(immersive) issue with the IPD value during rendering at runtime.
Hi Jeff,
I m preparing a demo in which i m facing 3D depth(immersive) issue.
Reference for stereo:http://forum.worldviz.com/showthread.php?t=4963
I have used the code in my script :
#-------------Code for setting 3D stereo setup start(i have used only IPD)----
bc= vizconfig.BasicConfigurable('3DViewSetter')
bc.addChoiceRadioItem('3D Format',[('Quad buffer',viz.QUAD_BUFFER)],\
viz.MainWindow.stereo,viz.MainWindow.getStereo)
bc.addFloatRangeItem('Inter-pulilary Distance',[-.5,.5],fset=viz.MainWindow.ipd,fget=viz.MainWindow.getIP D)
vizconfig.register(bc)
vizconfig.getConfigWindow().setWindowVisible(True)
#----------------------code for 3D setup stereo end----------------------------
But worldviz has alsomentioned:
http://docs.worldviz.com/vizard/commands/viz/ipd.htm
- the interpupilary distance in meters (default is 0.06 meters).
it takes ipd as 0.06. in the config window when i run the program and we get the 3D depth .
And after that we can change the ipd from config window,if 3D changes.
Issue:
The issue is when i navigate in room,sometimes the same IPD value 0.06(default),the 3D goes in between,and again i have to change the IPD to get the same depth.
Whats the difference between: viz.ipd(0.06) and viz.MainWindow.ipd(0.06),i m confused on this.
Is it compulsary to use the other values such as ,fusion distance,screen distance,fov in combination with IPD.
Which IPD should use- viz.ipd or viz.MainWindow.IPD to get the 3D Depth.
Thanx & Regards
Mr.Rajnish Vishwakarma
Software Developer
at
Xenium Digital Private Limited,Mumbai(Customer of World Viz)
Temporarily cease Oculus DK2 rendering or hide display willpower2727 Vizard 5 09-07-2016 09:39 AM
question about oculus rift DK2 and oculus runtime bbb Vizard 1 01-05-2016 11:23 PM
problem with DK2 runtime 0.8 dig Vizard 2 11-16-2015 02:49 AM
Loading at runtime EnvisMJ Vizard 3 06-22-2010 04:30 PM
