Old 07-11-2016, 03:18 AM
If you have an Enterprise license(s) you could use the 'Cave Manual Configuration' option in vizconnect and select front wall and floor. In the 'side image width' field enter the floor depth value.
If you're using a Development license this can be done through vizcave code directly. See the vizcave single machine example. However, there is no built-in vizconnect option available, it would require manual changes to the vizconnect code.
How to set offset for ART SmartTrack JB_HP_Viz Vizard 1 06-05-2016 11:02 PM
Four Wall Cave using two client cluster JB_HP_Viz Vizard 3 05-13-2016 04:26 AM
drives two walls with a single PC and an nVidia graphics card su.298@osu.edu Vizard 1 03-30-2012 09:53 AM
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 11:12 AM
