Old 07-08-2016, 01:13 AM
I'll check in with our developers and get back to you on both questions, orthographic projection and getting Vive specs. I'm not sure there is a Vizard command that will return the resolution and FOV of the Vive. You can use vizconnect or vizard commands to find out if a Vive is connected. Then you could retrieve specs saved to variables or a file. Would that work?
Regarding Viconnect viewpoint rajnishv Precision Position Tracker (PPT) 3 03-20-2017 11:03 PM
Regarding viewpoint with vizconfig,addFloatRangeItem&Storing viewpoint in PREFERENCES rajnishv Vizard 0 06-27-2016 03:57 AM
Projection Matrix (onto oblique near plane) andrewjworz Vizard 1 07-13-2012 09:10 AM
projection matrix control & child window kwkim Vizard 0 08-31-2011 12:53 AM
