Old 06-13-2016, 12:34 PM
jelly jelly is offline
For now, I think I have found the problem! It explains why I had the issue with the motion tracker on or off. The cause was not the tracker itself but the way the function which was writing the output was implemented. It was messing up the sampling, slowing it down, since the output file had to be opened, data saved and written each time.
Now that I am only saving data at each timepoint and writing it only once at the very end, the issue seems to be gone.
motion tracking, polhemus, timing
Motion Builder + Vizard Objects ForeverBound Vizard 1 04-01-2015 04:49 AM
Unusual tracker sensor setup with Vizard Zhi Vizard 2 06-12-2012 10:52 AM
problem in using xsens motion trackers in Vizard bharatbhushan Vizard 3 01-26-2009 06:51 PM
Can Vizard interact with the Arrington eye tracker? Deltcho Vizard 1 09-18-2007 03:38 PM
