Old 06-13-2016, 07:51 AM
dcnieho dcnieho is offline
apply transformations on vizconnect link
Dear All,
As part of our experiment setup, we use a few link operations to, e.g., rotate the virtual world with respect to the physical world. This worked fine before when i imported my own trackers and manually linked them to the MainView. With vizconnect, I can't get this to work, I am probably abusing something or missing a priority setting.
This is the example code
headTrack = vizconnect.getTracker('head_tracker')
headLink  = headTrack.getLink()
posRotationOperator = headLink.postEuler([0,0,0], target=viz.LINK_POS_OP)
posRotationOperator.setEuler([10,0,0])
# if i now try to see if the view differs from the raw tracker output, i see it doesn't:
print tuple(headTrack.getPosition(viz.ABS_GLOBAL)) + tuple(headTrack.getPosition(viz.ABS_GLOBAL)))
print tuple(headLink.getPosition(viz.ABS_GLOBAL)) + tuple(headLink.getEuler(viz.ABS_GLOBAL)))
print tuple(viz.MainView.getPosition(viz.ABS_GLOBAL)) + tuple(viz.MainView.getEuler(viz.ABS_GLOBAL)))
All three lines above print exactly the same position and orientation, irrespective of what operations i have active on the link. Could you tell me how i can make this work again (the exact same code, but with my manually created link between the tracker and the mainview works fine). this is an up to date Vizard 5.
Thanks!
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 05:19 AM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 09:45 AM
Introducing a rotation offset into a link EnvisMJ Vizard 1 11-13-2013 05:51 AM
Link only one Axis Andy Vizard 7 06-18-2013 02:30 AM
Pre/Post transformations pattie Vizard 5 10-02-2006 04:20 PM
