Old 03-22-2016, 05:01 AM
Seadna Seadna is offline
Question Multi-user crashing
Hi folks,
I have been testing the multi-user capabilities of vizard and it works with one user connected to the server. The problem is when a second user connects to the server the first client crashes.
Is this a known issue? I have been using the example code in the Vizard 5 Documentation.
Old 03-22-2016, 07:53 PM
Are all machines running the same version of vizard, such as Vizard 5.3 64 bit?
Are you running the code from the following page:
http://docs.worldviz.com/vizard/#Mul...nvironment.htm
This is not an issue I've heard of before.
Old 03-23-2016, 06:29 AM
I resolved this issue by starting again from the example code in the help file. All seems to be working ok now. Thanks for your reply.
crash, multi, user
Create object with position relative to user head, but cannot be obstructed by others Notch Vizard 2 03-03-2014 07:16 AM
multi user environment tutorial maya Vizard 0 11-23-2013 08:35 AM
multi user maya Vizard 1 11-18-2013 09:31 AM
Multi User Environment moneim230 Vizard 5 05-17-2011 05:56 PM
Controlling User Input ohad Vizard 1 03-15-2010 05:16 PM
