Old 03-09-2016, 03:19 AM
shashkes shashkes is offline
vizconnect optotrak sensors to avatar
I'm managing to connect to optotrak in a script by:
opto = viz.add('optotrak.dle',0,'192.168.1.1' )
body = opto.getBody(0) for m in opto.getBodyList():
ball = viz.add('white_ball.wrl',color=viz.RED,cache=viz.C ACHE_CLONE)
optolink1=viz.link(m,ball)
This provides me with two balls that follow the optotrak rigid bodies
but when I try to connect to optotrack through vizconnect with the same parameters I get:
** ERROR: Failed to load plug-in: 'optotrack.dle'
** WARNING: can't connect to Northern Digital Optotrack with index 0. It's likely that not enough sensors are connected.
Any idea why? My goal is to connect an avatar's hands to the optotrak sensors and use reverse kinematics, the simplest way seemed to be through vizconnect.
Is there any other way I could do this?
Sarah
Old 03-09-2016, 07:49 AM
Can you attach your vizconnect configuration file here?
Old 03-09-2016, 08:24 AM
attached in zip format
thanks
(the forum wouldn't allow .py files)
Old 03-09-2016, 09:20 PM
Do you get any errors when you run the following code?
body1 = opto.getBody(0)
body2 = opto.getBody(1)
Old 03-10-2016, 06:33 AM
this runs fine.
Old 03-11-2016, 12:48 AM
Attached is your configuration file modified to look for sensors 0 and 1. Run the file, go to the advanced configuration menu, and click on the trackers tab. Are both trackers showing a connection there? If not, is one of them connecting?
Old 03-11-2016, 03:12 AM
Thanks, I'll only have access to the lab on monday again. I'll keep you updated
Old 03-14-2016, 06:01 AM
none of the 2 trackers are showing a connection
any other ideas?
Sarah
Old 03-14-2016, 08:26 AM
Please contact support@worldviz.com and we'll help troubleshoot further.
Unexpected Avatar lookAt() behavior when using yield statements chris2307 Vizard 2 12-17-2013 03:58 AM
Avatar & Motion Capture Interface Angie Vizard 1 08-05-2010 07:17 PM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 10:44 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
