Old 02-25-2016, 04:39 AM
Seadna Seadna is offline
Question Spawn Avatar in front of User
Hi folks,
I have been trying to spawn an avatar model a few feet in front of the main view. I can get it to spawn at the location of the main view but not in front. I can offset the spawn location but not in relation to the viewpoint. Any help would be much appreciated.
def AddBot():
                x,y,z,d = viz.MainView.getAxisAngle()
                a,b,c = viz.MainView.getPosition()
                modelfile = randint(1,3)
                dudestate = randint(1, 14)
                if modelfile == 1:
                                dude = viz.add('vcc_male.cfg')
                elif modelfile == 2:
                                dude = viz.add('vcc_male2.cfg')
                elif modelfile == 3:
                                dude = viz.add('vcc_female.cfg')
                dude.state(dudestate)
                dude.setPosition(a + 5,b,c, viz.REL_LOCAL)
                dude.setAxisAngle(0,y,0,d)
                ColShape = Cloud.collideMesh()
                dude.collideCapsule()
vizact.onbuttondown(button_addbot, AddBot)
Old 02-25-2016, 06:08 AM
Here's an example, navigate around and you'll see a pigeon appear in front of the view every two seconds:
viz.addChild('piazza.osgb')
avatar = viz.addAvatar('pigeon.cfg',pos=[0,0,6],euler=[180,0,0],scale=[4,4,4])
avatar.state(1)
def spawnAvatar():
	yaw = viz.MainView.getEuler()[0]
	vector = viz.MainView.getMatrix().getForward()
	amount = 5
	x,y,z = vizmat.MoveAlongVector(pos,vector,amount)
	a = avatar.clone(pos=[x,0,z],euler=[yaw-180,0,0],scale=[4,4,4])
vizact.ontimer(2,spawnAvatar)
Old 02-25-2016, 07:16 AM
Thank you,
This worked like a charm.
Old 02-29-2016, 04:16 PM
JasmineJasmine JasmineJasmine is offline
You can use the player.transform.forward direction to get the players direction as a vector and transform.rotation to get the orientation. You can also do math operations of vectors which makes things so much better than modifying the components.
avatar, position, relative, viewpoint
Unexpected Avatar lookAt() behavior when using yield statements chris2307 Vizard 2 12-17-2013 03:58 AM
Avatar eye contact with user as it moves Ducky Vizard 1 03-01-2013 01:23 PM
How to make avatar always in front of youself (e.g. 20cm) when direction changes Xianshi Xie Vizard 2 06-30-2009 12:13 PM
Has user perception of avatar expressions been tested? Karla Vizard 3 10-28-2008 11:32 AM
