Old 02-01-2016, 03:29 AM
jelly jelly is offline
playing a sound multiple times at different timings
Dear all,
I am new to Vizard and to programming in general. I need to use it to program an experiment for my studies and while I have already done a number of tutorials, I still feel quite insecure. I wanted to ask for your help with the following:
I am trying to create a function that will basically call my trial (displaying two 2D pictures on the screen and playing some sounds). Because I got stuck at the sounds part, I started a new Vizard file just for the sound to try out different things.
I want the sound to play 10 times. I figured a loop should do the trick, but I can't seemt o find a way to do that...I've looked at sound.loop(viz.ON) and at viz.playSound('pip.wav', viz.LOOP) but these are endless loops. Here is what I have so far:
#stimulus
pip = viz.addAudio('pip.wav')
#Import Vizard modules:
import viz import time
import viztask
#Start
#Sounds
cue = 1
while cue <= 10:
pip.play() # This should be executed 10 times
#viz.playSound('pip.wav')
cue += 1
But this doesn't play the sound 10 times...Not to mention that, ideally, I would want the sound to play at randomly intersperced intervals until the last (10th) sound is played. But that will be my next challenge. First, I need to figure out how to play the sound 10 times.
I would be really greatful for any pointers in the right direction! Thank you very much in advance!
Jelly
sound loop
preEuler not working? or how to teleport subject multiple times ichitaka Precision Position Tracker (PPT) 1 12-19-2015 04:27 AM
output to multiple (two) sound devices GiudiceLab Vizard 1 08-05-2009 02:12 PM
Multiple Sound Devices GiudiceLab Vizard 2 06-06-2009 11:29 AM
how can I detect when a sound finished playing? bernie Vizard 3 05-10-2007 07:08 PM
Error when playing wav files...? vjonshih Vizard 1 05-23-2005 01:21 PM
