Old 12-08-2015, 02:47 PM
SivaKartheek SivaKartheek is offline
Regarding Walking Action of Avatars
Hello Everyone,
Good Morning , I am having some problem with walking action. Even though my position and my code is correct the avatar is not walking according to the point that i have given (avatar is roaming inside the model and after that reaching the final point)
The avatar walks properly for the first time but for the same code and same points the avatars walks in a different way.
can anyone please give me some suggestions how can i resolve this problem
Thank you
Old 12-09-2015, 10:32 PM
Depending on the initial orientation of the avatar, the path it takes to reach the final point may vary because of the turns it has to make. Is this what you're describing? You can force the avatar to turn in place and face the destination point before it starts walking. Either use the vizact.turn command or set the turnInPlace argument to True:
walk = vizact.walkTo([0,0,15],turnInPlace=True)
Old 12-10-2015, 08:10 AM
Thanks jeff but my question is not abut that.
Actually I arranged 40 pedestrains in a list and then i have a data of 40 avatars in a xml file. Some avatars are moving properly and then reaching destination but some of them are rotating some time and then reaching destination . I don't Understand why they are rotating like that
if you know regarding this , can you please give me an idea why the avatars behaving like that
thankyou
problems with walking women avatars armo Vizard 6 04-07-2015 07:38 AM
Vizard tech tip: Blinking Avatars Jeff Vizard 3 11-24-2009 01:16 PM
How to make avatars to follow terrain while walking? yyang Vizard 1 08-04-2008 02:54 PM
Avatars in an array and link/unlink betancourtb82 Vizard 7 09-05-2006 04:06 PM
Walking avatars --> collision detection? sjroorda Vizard 3 10-13-2005 04:47 AM
