Old 12-03-2015, 12:10 AM
Paul Paul is offline
Registered User
Problem "import parallel"
I'm doing a program in Python using Vizard 5 Free, and I have a "parallel import" that I need to send a signal through the parallel port, but I get this error ... how can I fix?
Thank you!
** Loading provaparallela.py
File "<string>", line 11, in <module>
File "C:\Documents and Settings\Administrator\Desktop\provaparallela.py", line 1, in <module>
?import parallel
ImportError: No module named parallel
** Load Time: 0.01 seconds
Old 12-04-2015, 10:57 AM
There is no module called 'parallel' included with Python or Vizard by default. This is most likely referring to a Python add-on library that you need to install separately. You can use the package manager to install Python add-on packages.
Problem: import .osgb from vizard roosfcch Vizard 1 04-09-2014 09:45 PM
Mesh and Texture Import Problem! kfootball15 Vizard 2 03-11-2014 10:41 AM
Proximity Sensor Problem kmkm Vizard 3 03-04-2014 11:54 AM
A problem with cave apmx Vizard 0 10-28-2013 04:37 AM
Problem with database import pattie Vizard 1 09-02-2006 11:15 AM
