Old 12-02-2015, 04:02 PM
These are satellite images. Normal resolution is 2k x 2k
Each frame has to be decompressed to RGB and uploaded to the GPU and then applied as a texture in Vizard. If the amount of image data exceeds the GPU memory then you could have framerate drops.
Light Baking in 3DS Max causing models to render with seams and transparent faces dproeder Vizard 1 09-17-2013 06:45 PM
Setting up render node for shadowing whaleeee Vizard 2 05-06-2013 10:20 AM
To Masaki regarding render nodes surf3rguy Vizard 1 04-17-2012 05:37 PM
