Old 12-02-2015, 07:57 AM
sbilleter sbilleter is offline
vizdlg inside a vizinfo
Is it possible to integrate a AskDialog into an InfoPanel ?
It seems that it is possible to add a vizdlg.Panel as a simple part of the InfoPanel
(Custom GUI Layout of the Vizard documentation). And as the AdkDialog is inheritating from the Dialog and then the Panel, it should be possible, but for the moment, my InfoPanel is just empty
Can you help me ?
it would be much easier than recreating the Askdialog inside the InfoPanel.
Thanks.
Stéphane
Old 12-04-2015, 10:53 AM
Yes, here's an example:
import vizinfo
import vizdlg
import viztask
info = vizinfo.InfoPanel('An InfoPanel with Dialog')
info.addSeparator()
options = [('Option 1'),('Option 2')]
dialog = vizdlg.AskDialog(options=options, title='Ask Dialog')
info.addItem(dialog)
def showdialog():
    while True:
        dialog.selection = 0
        yield dialog.show()
        if dialog.accepted:
            print 'accepted', options[dialog.selection]
            print 'cancelled'
        yield viztask.waitTime(1)
viztask.schedule(showdialog())
vizdlg, vizinfo
Draw order of vizinfo Panel mape2k Vizard 2 10-08-2015 02:59 PM
vizinfo, vizdlg related questions mape2k Vizard 4 07-27-2015 03:46 AM
check user input using vizinfo panel armo Vizard 0 01-22-2015 02:05 AM
Vizinfo box: help with aligning text Woosuk Jang Vizard 4 07-15-2010 04:01 PM
Modifying Vizinfo to Support Re-parenting Tip Gladsomebeast Vizard 0 12-16-2008 05:34 PM
