Old 09-23-2015, 06:06 AM
unabhan unabhan is offline
Vizard 5.2 and Oculus health warning
I recently updated to 5.2 and noticed that the health warning can't be turned of pressing a key using render mode oculus.RENDER_SDK, so no direct to rift mode - or edit the windows registry to ad the disable option to the Oculus config.
Just for the record ...
Old 09-24-2015, 05:49 AM
armo armo is offline
I am experiencing this problem, too. How can I fix it?
I have the Vizard 5.2 version and the Oculus Runtime 0.4.4
regards,
armo
Old 09-25-2015, 05:34 AM
Zhi Zhi is offline
I got the same issue. Is this problem specific to Vizard 5.2? It could be bug, I guess. By the way, I added the key in the windows registry, but it did not work. Don't know why.
Old 09-29-2015, 08:55 AM
jokr jokr is offline
Registered User
Go to your sys tray -> right click on Oculus -> Configuration Utility -> Advanced -> check "disable health and security warning"
Old 09-29-2015, 11:58 AM
The health warning is caused by the Oculus runtime version, not the Vizard version. If you're running runtime 0.5.0.1 or above you'll need to create a registry key. Once you've done that an option to disable the warning should be shown in the Oculus runtime app. You can find instructions online for the registry edit.
Old 09-30-2015, 02:20 AM
Hi jeff,
I have installed the Vizard 5.2 version and the Oculus Runtime 0.4.4, but I am still encountering this problem.
Specifically, when I run the "oculusExample.py" file, the warning stands still on the screen and does not disappear, whatever I do (pressing a key, pressing the mouse button, waiting for a long time without pressing anything, ecc.)
Old 10-01-2015, 03:31 AM
Add "disable health and security warning" to Oculus config util
You'll have to edit the registry open a command window as Administrator
and run RegEdit.exe
If your Windows is 32-bit go to:
HKEY LOCAL MACHINE\Software\Oculus VR, LLC\
If it is 64-bit, go to:
HKEY LOCAL MACHINE\Software\Wow6432Node\Oculus VR,LLC\
then add a new key called LibOVR
to this key add new string called valueHSWToggleEnabled
and set it value to 1.
When you open the Oculus config util and click advanced there will be a new line with the "disable health and security warning" Option.
Good luck
Old 10-30-2015, 07:34 AM
hzhao hzhao is offline
I have this problem too.
I use vizard 5.2, Oculus runtime 0.6.0.1 on widows 8, 64bit. I have added the key and value in windows registry as suggested above. But it doesn't work, the warning message remains there.
Anyone has solution?
I am thinking about re-installing vizard 5.1. Does anyone know if vizard 5.1 has the same problem?
Thanks.
Old 11-30-2015, 04:45 AM
johnallen johnallen is offline
tap tap
Ok, so does anyone have a fix for this yet?
I've stumbled across a work around (I wouldn't go so far as to call it a fix).
I've setup the registry key (see above) for a W8.1 x64 box but the safety warning messag isn't cleared by key presses, *however* if I gently tap the side of the rift unit (as if tapping my temple) then the message is cleared. Bizarre!
I'd be interested to know if this is just for my unit?
A proper fix would be appreciated.
(vizard 5.2 x64 & HMD firmware 2.12 )
oculus rift, vizard 5.0
Blank screen on external monitor when running a Vizard script with Oculus DK2 mstan Vizard 4 09-03-2015 06:58 AM
oculus DK2 in vizard 5 green951 Vizard 1 06-18-2015 09:12 AM
Vizard 4 Oculus Rift support? NIgroupOS Vizard 1 03-09-2015 04:43 AM
Oculus DK1 and DK2 in Vizard 5 Jeff Vizard 3 10-02-2014 12:00 PM
Oculus DK2 and Vizard 5 seal Vizard 0 08-28-2014 01:46 PM
