Old 11-09-2015, 09:27 AM
Does it work when you run from the source file?
Old 11-09-2015, 10:49 AM
sonika sonika is offline
I'm using the following script.
import sys
import oculus
viz.setMultiSample(4)
viz.fov(60)
hmd = oculus.Rift()
viz.link(hmd.getSensor(), viz.MainView)
env = viz.addEnvironmentMap('beachscene.png')
sky = viz.addCustomNode('skydome.dlc')
sky.texture(env)
But when i run the script, all i get is a blank new window. I am not able to see the 360 panorama. Cannot create an executable. Am I missing something?
Old 11-10-2015, 11:08 AM
Any suggestion Jeff?
Running the script does not result in anything at all. Just opens another blank screen window.
I'm assuming loading the 6 cube images into a 360 panorama should be a fairly simple step as thats all I need to do. No animations or modeling involved.
Is there any reference that I should look at for the script? or can someone help me with that?
Thanks much.
Old 11-10-2015, 01:50 PM
Can you attach the environment map images here?
Old 11-12-2015, 12:01 PM
Jeff,
I have uploaded my files on WorldViz server. The reference number is 1499183.
Old 11-12-2015, 02:25 PM
Your script worked for me and displayed the panorama within the DK2. Perhaps the Oculus is not connecting on your machine. Try running the oculusExample.py script included with the Vizard installation and verify that works. Currently Vizard is not compatible with Oculus runtimes 0.7 and above.
Panorama view and binary image jai Vizard 4 11-26-2015 08:52 PM
Oculus Rift and 360 Panorama with Vizard Lite Edition mshukun Vizard 4 11-10-2015 11:17 AM
360 panorama walk around mshukun Vizard 1 04-24-2015 04:04 PM
360 panorama image cube using as darts target and record the xy coordinates mshukun Vizard 2 03-14-2013 06:17 AM
Page flip stereo panorama renderwiz Vizard 3 06-21-2007 10:12 AM
