Old 10-30-2015, 06:34 AM
hzhao hzhao is offline
I have this problem too.
I use vizard 5.2, Oculus runtime 0.6.0.1 on widows 8, 64bit. I have added the key and value in windows registry as suggested above. But it doesn't work, the warning message remains there.
Anyone has solution?
I am thinking about re-installing vizard 5.1. Does anyone know if vizard 5.1 has the same problem?
Thanks.
Old 11-30-2015, 03:45 AM
johnallen johnallen is offline
tap tap
Ok, so does anyone have a fix for this yet?
I've stumbled across a work around (I wouldn't go so far as to call it a fix).
I've setup the registry key (see above) for a W8.1 x64 box but the safety warning messag isn't cleared by key presses, *however* if I gently tap the side of the rift unit (as if tapping my temple) then the message is cleared. Bizarre!
I'd be interested to know if this is just for my unit?
A proper fix would be appreciated.
(vizard 5.2 x64 & HMD firmware 2.12 )
oculus rift, vizard 5.0
Blank screen on external monitor when running a Vizard script with Oculus DK2 mstan Vizard 4 09-03-2015 05:58 AM
oculus DK2 in vizard 5 green951 Vizard 1 06-18-2015 08:12 AM
Vizard 4 Oculus Rift support? NIgroupOS Vizard 1 03-09-2015 03:43 AM
Oculus DK1 and DK2 in Vizard 5 Jeff Vizard 3 10-02-2014 11:00 AM
Oculus DK2 and Vizard 5 seal Vizard 0 08-28-2014 12:46 PM
