Old 09-30-2015, 01:20 AM
armo armo is offline
Hi jeff,
I have installed the Vizard 5.2 version and the Oculus Runtime 0.4.4, but I am still encountering this problem.
Specifically, when I run the "oculusExample.py" file, the warning stands still on the screen and does not disappear, whatever I do (pressing a key, pressing the mouse button, waiting for a long time without pressing anything, ecc.)
Old 10-01-2015, 02:31 AM
unabhan unabhan is offline
Add "disable health and security warning" to Oculus config util
You'll have to edit the registry open a command window as Administrator
and run RegEdit.exe
If your Windows is 32-bit go to:
HKEY LOCAL MACHINE\Software\Oculus VR, LLC\
If it is 64-bit, go to:
HKEY LOCAL MACHINE\Software\Wow6432Node\Oculus VR,LLC\
then add a new key called LibOVR
to this key add new string called valueHSWToggleEnabled
and set it value to 1.
When you open the Oculus config util and click advanced there will be a new line with the "disable health and security warning" Option.
Good luck
oculus rift, vizard 5.0
Blank screen on external monitor when running a Vizard script with Oculus DK2 mstan Vizard 4 09-03-2015 05:58 AM
oculus DK2 in vizard 5 green951 Vizard 1 06-18-2015 08:12 AM
Vizard 4 Oculus Rift support? NIgroupOS Vizard 1 03-09-2015 03:43 AM
Oculus DK1 and DK2 in Vizard 5 Jeff Vizard 3 10-02-2014 11:00 AM
Oculus DK2 and Vizard 5 seal Vizard 0 08-28-2014 12:46 PM
