Old 09-21-2015, 01:43 AM
hzhao hzhao is offline
Question how to reduce motion sickness with Oculus rift+logitech driving force
I am setting up my Oculus rift DK2 with Logitech driving force GT. To use these two, I combined the two demo codes for Oculus and joy stick control (attached below). It works. But I don't feel well when I use this setup because of the very strong motion sickness. I used the position tracking from Oculus. Could anyone give me some help to improve it? reduce the motion sickness? Thanks.
the code I used:
hmd = oculus.Rift()
# Get list of joystick device information
dinput = viz.add('DirectInput.dle')
devices = dinput.getJoystickDevices()
joy = dinput.addJoystick(devices[selected])
joy.setDeadZone(0.05)
# Check if HMD supports position tracking
supportPositionTracking = hmd.getSensor().getSrcMask() & viz.LINK_POS
if supportPositionTracking:
# Add camera bounds model
camera_bounds = hmd.addCameraBounds()
camera_bounds.visible(False)
# Change color of bounds to reflect whether position was tracked
def CheckPositionTracked():
if hmd.getSensor().getStatus() & oculus.STATUS_POSITION_TRACKED:
camera_bounds.color(viz.GREEN)
camera_bounds.color(viz.RED)
vizact.onupdate(0, CheckPositionTracked)
# Setup navigation node and link to main view
navigationNode = viz.addGroup()
HMDviewLink = viz.link(navigationNode, viz.MainView)
HMDviewLink.preMultLinkable(hmd.getSensor())
# Apply user profile eye height to view
profile = hmd.getProfile()
if profile:
HMDviewLink.setOffset([0,profile.eyeHeight,0])
HMDviewLink.setOffset([0,1.8,0])
########################### joystick turn and move speed###############
joy_MOVE_SPEED = 2.0
joy_TURN_SPEED = 60.0
def UpdateView():
########for joy control############
e = viz.elapsed()
x,y,z = joy.getPosition()
navigationNode.setEuler([x * joy_TURN_SPEED * e, 0, 0], viz.REL_LOCAL)
navigationNode.setPosition([0, 0, (y+1) * joy_MOVE_SPEED * viz.getFrameElapsed()], viz.REL_LOCAL)
vizact.ontimer(0,UpdateView)
Old 09-21-2015, 04:11 PM
I would suggest looking online for best practices to reduce motion sickness in VR. Make sure you're simulation is running at 75 fps and use Direct HMD mode to reduce latency. Latency and virtual movements that don't match physical movements can cause motion sickness. You might see if gradual acceleration rather than instantaneous changes to the car speed helps. Also, see if adding a dashboard as a fixed reference in the scene helps.
Old 09-23-2015, 06:34 AM
Thanks, Jeff,
I tried adding a dashboard, but it helped little. I'll try your other suggestions. Thanks again.
controller, driving force, motion sickness, oculus rift
Oculus Rift Drift teklab Vizard 20 04-01-2016 07:57 AM
Oculus Rift and 360 Panorama with Vizard Lite Edition mshukun Vizard 4 11-10-2015 11:17 AM
Multiple post-process effects with oculus rift lklab Vizard 2 03-13-2015 01:48 PM
Oculus Rift connection problem mshukun Vizard 1 10-01-2014 12:15 PM
Oculus Rift Fullscreen teklab Vizard 6 05-21-2014 06:11 AM
