Old 07-24-2015, 11:44 AM
Yes, you can link the pencil tool to any object. You could either activate the pencil draw command with an input signal (mouse button, keypress, etc.) or have it draw continuously.
Old 07-24-2015, 02:14 PM
Daniel Daniel is offline
Hi Jeff, thank you for your answer
Could you please show me an example of a pencil attached to an object and drawing continuosly? Because I can't make it work properly
Old 07-28-2015, 05:06 PM
Take a look at the pencil documentation for commands available. The following example script executes the draw command continuously:
Right mouse button clears the drawing.
Middle mouse button changes color.
Mouse movements control viewpoint orientation.
Arrow Keys control viewpoint position.
import vizshape
import vizinfo
vizinfo.InfoPanel(align=viz.ALIGN_LEFT_BOTTOM)
viz.setMultiSample(4)
viz.fov(60)
piazza = viz.add('piazza.osgb')
arrow = vizshape.addArrow(length=0.2, color = viz.RED)
from tools import pencil
tool = pencil.Pencil()
# update code for pencil
def update(tool):
	state = viz.mouse.getState()
	if state & viz.MOUSEBUTTON_RIGHT:
		tool.clear()
	elif state & viz.MOUSEBUTTON_MIDDLE:
		tool.cycleColor()
		tool.draw()
tool.setUpdateFunction(update)
#Link the pencil tool to an arrow
#Then move the arrow in the reference frame of the viewpoint
from vizconnect.util import virtual_trackers
mouseTracker = virtual_trackers.ScrollWheel(followMouse = True)
mouseTracker.distance = 1
arrowLink = viz.link(mouseTracker,arrow)
arrowLink.postMultLinkable(viz.MainView)
viz.link(arrowLink,tool)
import vizcam
vizcam.FlyNavigate()
#Hide the mouse cursor
viz.mouse.setVisible(viz.OFF)
Old 07-29-2015, 09:41 AM
Thank you Jeff, but what I can't do is to attach the pencil to an osgb object (in this case the robot end effector), how can I do that?
Thank you in advance
Rotate object around mainView? performlabrit Vizard 3 12-19-2013 06:31 AM
AMD graphics hardware seems not to preload object sleiN13 Vizard 2 03-20-2012 06:08 AM
