Old 07-10-2015, 10:23 AM
Support for wrapping text in vizdlg panels will be added in a future update. In the meantime, you can use the following code to enable text wrapping with Vizard 5.1:
import vizdlg
class WrappedText(viz.VizText):
	def __init__(self, message, wrapWidth=None, **kw):
		viz.VizText.__init__(self,viz.addText(message, **kw).id)
		self._wrapWidth = None
		self.setWrapWidth(wrapWidth)
	def setWrapWidth(self, width):
		"""Set width at which text is wrapped"""
		if width != self._wrapWidth:
			self._wrapWidth = width
			if width is None:
				self.setBoxTransform(viz.BOX_DISABLED)
				self.setBoxTransform(viz.BOX_ENABLED | viz.BOX_FIXED)
				self.setBoxOffset([0.0, 0.0, width, 0.0])
				self.setTextOverflow(viz.OVERFLOW_WRAP)
			parent = getattr(self, '_parentPanel', None)
			if parent is not None:
				panel = parent()
				if panel is not None:
					panel.dirtyLayout()
	def getWrapWidth(self):
		"""Get width at which text is wrapped"""
		return self._wrapWidth
message = "Lorem ipsum dolor sit amet, consectetur adipiscing elit. Proin sodales tellus nunc, id molestie felis rutrum id. Vestibulum gravida fermentum tortor ac fringilla. Maecenas ac eleifend enim, vitae rutrum odio. Interdum et malesuada fames ac ante ipsum primis in faucibus. Duis consectetur maximus ipsum, at fermentum orci tincidunt vitae. Donec tempus lectus ut auctor hendrerit. Curabitur iaculis volutpat arcu sit amet commodo. Nulla facilisi. Phasellus ut quam non lorem facilisis laoreet vel sed felis. Mauris sed nisi a lorem euismod ornare."
panel = vizdlg.Panel()
panel.setScreenAlignment(viz.ALIGN_CENTER)
text = panel.addItem(WrappedText(message, wrapWidth=200))
grow_action = vizact.call(text.setWrapWidth, vizact.mix(begin=200, end=500, time=1.0, interpolate=vizact.easeOutStrong))
shrink_action = vizact.call(text.setWrapWidth, vizact.mix(begin=500, end=200, time=1.0, interpolate=vizact.easeOutStrong))
vizact.onkeydown(' ', text.runAction, vizact.choice([grow_action,shrink_action]))
check user input using vizinfo panel armo Vizard 0 01-22-2015 03:05 AM
changing font color in vizdlg purdue_vr Vizard 1 09-17-2009 06:43 PM
Modifying Vizinfo to Support Re-parenting Tip Gladsomebeast Vizard 0 12-16-2008 06:34 PM
General Questions about Vizard: World Viz dav Vizard 5 08-28-2006 04:44 PM
vizinfo vadrian Vizard 1 11-05-2004 03:40 PM
