Old 06-15-2015, 04:29 PM
I'll have to check with a developer for further assistance.
Old 06-26-2015, 12:49 PM
1) There is a bug that involves the panel scaling and fontsize. This will be fixed in the next Vizard release. However, there is a workaround which is actually better than setting the font size. You can apply an additional scale to the "gridPanel", which will be relative to it's inherited scale from the parent tabPanel. So instead of changing the font size, do something like the following:
gridPanel.setPanelScale(1.75)
Below is an example:
import vizdlg
tabPanel = vizdlg.TabPanel()
gridPanel = vizdlg.GridPanel()
tabPanel.addPanel('TEST',gridPanel,viz.ALIGN_LEFT_TOP)
rowText = viz.addText('TEXT')
gridPanel.addRow([rowText])
viz.link(viz.LeftTop,tabPanel,offset=(10,-10,0))
vizact.onkeydown('1',tabPanel.setPanelScale,1)
vizact.onkeydown('2',tabPanel.setPanelScale,2)
2) Yes, only GUI objects will scale with the panel scale. If you just want to have a textured quad you could add a textured checkbox and that will scale with the panel:
quad = viz.addCheckbox()
quad.setScale([3,3,1])
quad.disable()
quad.texture(viz.addTexture('lake3.jpg'))
gridPanel.addRow([quad])
Custom-permanent tooltip tokola Vizard 2 06-09-2015 01:20 PM
