Old 06-08-2015, 09:57 AM
Trever.R Trever.R is offline
Question Shadow Map Bakes with vizfx.addchild
Hello, recently I worked out how to get normal maps and specular maps to work properly in vizard by adding assets through the vizfx.addchild command. However by using that, it seems to not be able to take the shadow map bakes that I have created. Whenever I try to export a file with a bake on it, the baked map ends up tiled all over the object. Does anyone have any idea how to go about this, or is it not possible to use baked maps with vizfx?
Old 06-08-2015, 10:30 AM
If you're using the shader workflow, the light map should be placed in the Ambient color slot rather than the Self-Illumination slot.
Old 06-09-2015, 08:33 AM
I tried putting the map into the ambient color slot, and the results are way too bright (see attached image). Any idea whats causing that? I didn't have any lights coded in when I ran it so it can't be that.
Name:	Light Map EX.png
Old 06-09-2015, 08:47 AM
And here is the light map I generated. Its generated as a tga, I just screenshoted it here because tga isnt supported on the forums.
Old 06-09-2015, 10:35 AM
Hi Trever,
What's going on here is that your lightmap is currently overexposed. In the the shader 50% brightness is treated as the neutral exposure value, so anything lighter will be brighter than the original texture and anything darker will darken it. This allows for the scene to represent areas of intense light, which is impossible when only darkening the scene.
This is similar to using the "Self-Illumination Scale: 2x" export option that could be used with the old workflow.
The solution here is to adjust the exposure and re-render your lightmaps so everything you want to have a neutral exposure has a brightness of 50%. You final lightmap should look something like the attached image.
baked, lighting vizard osgb, shadowmaps, vizfx
shadows in mirror chris_user Vizard 0 02-17-2011 03:37 AM
Shadow Module and Shaders mruss7 Vizard 1 07-27-2010 01:00 PM
how to change shadow direction? shahramy Vizard 2 05-05-2010 09:37 PM
setEuler method of Shadow module omidbrb Vizard 1 02-22-2010 09:35 AM
RE: Shadow Module nige777 Vizard 2 05-08-2008 04:52 PM
