Old 05-27-2015, 08:49 AM
Make sure you use the vizfx library to load the model.
If the model was exported correctly, you'll also be able to see the effects by opening it in Inspector. Make sure 'effects' is enabled.
3dsmax, documentation, effect, shader
Enabling Effects in Vizard 5? shivanangel Vizard 8 05-27-2014 04:13 AM
Texture Coordinate Generation (TexGen) using Shader goro Vizard 1 05-31-2013 01:44 AM
SSAO Shader Implementation FranciscoPeters Vizard 2 10-08-2011 04:19 AM
Multiple Textures for Diffuse and Specularity Shader Issue shivanangel Vizard 1 05-11-2009 10:44 AM
Specular Shader Issue shivanangel Vizard 2 05-06-2009 11:08 AM
