Old 04-09-2015, 03:19 PM
MissingAFew MissingAFew is offline
Offset position of link/attached object
How do you change the relative offset of an attached object when using viz.link? Is this possible? setPosition doesn't work and there doesn't seem to be a set relative position function. Also need the rotation as well.
Problem with object position Ryvan Vizard 2 01-22-2015 02:01 PM
How to get real time position of a object which is connected to a haptic device Melody Vizard 4 09-15-2014 03:35 PM
Create object with position relative to user head, but cannot be obstructed by others Notch Vizard 2 03-03-2014 08:16 AM
Can you link the position of a tracker to the orientation of an object? michaelrepucci Vizard 1 09-19-2008 11:23 AM
