Old 04-06-2015, 11:47 AM
BSUGeek BSUGeek is offline
Question Proximity event when avatar enters
Hi I need help trying to figure out how can you tell when an avatar enters a proximity sensor. Once the avatar enters the proximity its health is supposed to deplete. I'm not really sure where to start. Is there a way to tell when a sensor enters another sensor?
Old 04-07-2015, 09:05 AM
Erikvdb Erikvdb is offline
Just make your avatar a vizproximity Target
target = vizproximity.Target(avatar)
manager.addTarget(target)
def EnterProximity(e):
    if e.target == target:
        print "Avatar is losing health"
manager.onEnter(None, EnterProximity)
*Code assumes you have already set up your proximity manager, avatar and sensor(s).
Old 04-07-2015, 09:07 AM
Oh! Wow thanks! I had no idea we could do that!
Old 04-14-2015, 10:43 AM
sportykourty sportykourty is offline
Proximity Sensor Event
So I was trying to incorporate the previous code but I'm stuck. does my sensor and target have to be in the same manager? I'm not really sure what I'm doing wrong but the function never executes.
sensor = vizproximity.Sensor(vizproximity.Sphere(15,center = [72,-.57,2]), source = avatar1)
manager.addSensor(sensor)
Avatar2Target = vizproximity.Target(avatar2)
Avatar2Manager.addTarget(Avatar2Target)
def HealthLoss(e):
	if e.target == Avatar2Target:
		print "Sensor Entered"
Avatar2Manager.onEnter(sensor1, HealthLoss)
Old 04-15-2015, 02:54 AM
Yes, all targets and sensors that interact with each other have to be assigned to the same manager.
Here's a complete code example:
import vizproximity
# Physical Objects
ball = viz.addChild('beachball.osgb',pos=[-1,0.2,0])
avatar = viz.addAvatar('vcc_male2.cfg',pos=[1,0,0])
avatar.setEuler([180,0,0])
avatar.state(5)
# Proximity Management
manager.setDebug(viz.ON)
sensor = vizproximity.Sensor(vizproximity.Sphere(0.5, center=[0,0,0]), ball)
def healthLoss(e):
manager.onEnter(sensor, healthLoss)
# Demo
def update():
	if viz.key.isDown(viz.KEY_LEFT):
		avatar.setPosition([-2*viz.elapsed(),0,0],viz.REL_GLOBAL)
	elif viz.key.isDown(viz.KEY_RIGHT):
		avatar.setPosition([2*viz.elapsed(),0,0],viz.REL_GLOBAL)
vizact.ontimer(0,update)
viz.MainView.setPosition([0,1,-4])
Use arrow keys to move the avatar to the ball.
Created in Vizard 4.
Old 04-16-2015, 09:32 AM
Wow thanks! that's really helpful. So if I want the health to continue to drop until I exit the proximity would i just do a While(true) loop?
Old 04-21-2015, 01:53 AM
No, entering and exiting a proximity are two separate events. Use them to toggle a state that you can check for in the general update loop.
health = 100
healthloss = False
def onEnter(e):
		healthloss = True
def onExit(e):
		healthloss = False
manager.onEnter(sensor, onEnter)
manager.onExit(sensor, onExit)
# Demo
def update():
	if healthloss:
		health -= 2 * viz.elapsed()
Unexpected Avatar lookAt() behavior when using yield statements chris2307 Vizard 2 12-17-2013 03:58 AM
Avatar & Motion Capture Interface Angie Vizard 1 08-05-2010 07:17 PM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 10:44 AM
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 06:52 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
