Old 03-12-2015, 09:27 AM
shall6 shall6 is offline
Thanks for the assist - can't believe I missed that. Now I'm on to the hard part (been hunting through old threads but no answer).
When I run with the if statement, I can't get it to work. It has to do with the data coming through as e.raw_data. I tried converting it to a string but I still can't compare it. This is what I have after trying to convert BOTH my data and my if object (already a string) to strings. It still doesn't work. Of course it will recognize them as NOT equal... but that doesn't help me much. Why can't I actually turn this raw data into an object?
dataNetwork = viz.addNetwork('OEM-PC')
def onNetwork(e):
    if isinstance(e,viz.RawNetworkEvent):
        print e.raw_data
        v = str(e.raw_data)
        if v == str('hi'):
            print v
viz.callback(viz.NETWORK_EVENT,onNetwork)
Thanks!
Old 03-12-2015, 09:46 AM
Try using the following code to see what the contents of the raw_data attribute is:
def onNetwork(e):
        print repr(e.raw_data)
Keep in mind that the raw data can contain trailing NULL (\x00) byte values, so you might need to account for this if you are expecting to receive a string.
Old 03-12-2015, 09:52 AM
That's exactly it
I got 'hi\n'
Any chance there's a simple way to remove the trailing parts?
Old 03-12-2015, 09:55 AM
You can use the following to strip trailing newline, space, and null byte characters:
v = e.raw_data.rstrip('\n\0 ')
Interface between Matlab and Vizard Shweta Vizard 8 06-30-2014 09:40 AM
Iinterface between MATLAB and Vizard suraj Vizard 7 07-17-2012 09:02 AM
MATLAB and vizard xingtzu Vizard 1 01-15-2008 10:25 AM
Matlab and Vizard brystewa Vizard 1 09-18-2006 03:11 PM
MATLAB and Vizard eagleman Vizard 4 06-10-2005 11:42 AM
