I don't understand the issue. An action is applied to both the ground object and the viewpoint. Is that what you want? The shape is not being moved. You can check the shape position by adding the following code:
def printShapePosition(): print h.getPosition(viz.ABS_GLOBAL) vizact.ontimer(1,printShapePosition) |
| Tags |
| mainview, movement, newb |
| Thread Tools | |
| How to get real time position of a object which is connected to a haptic device | Melody | Vizard | 4 | 09-15-2014 03:35 PM |
| Create object with position relative to user head, but cannot be obstructed by others | Notch | Vizard | 2 | 03-03-2014 08:16 AM |
| Object + InteriaCube + Viewport problem | Gekitatsu | Vizard | 1 | 02-22-2012 11:55 AM |
| Can you link the position of a tracker to the orientation of an object? | michaelrepucci | Vizard | 1 | 09-19-2008 11:23 AM |
| picking problem... | k_iwan | Vizard | 2 | 07-27-2007 08:57 PM |
