Yes, you can give a model name as the Y position of the walkTo command. The walkTo will adjust the height of the avatar to match the height of the model:
import vizmat
viz.setMultiSample(4)
viz.fov(60)
viz.clearcolor(viz.SLATE)
viz.addChild('ground.osgb')
viz.move([0,0,-2])
quad = viz.addTexQuad(pos=[0,0,4.5],euler=[0,65,0],scale=[2,10,1],color=viz.RED)
quad2 = viz.addTexQuad(pos=[0,0,13.50],euler=[180,65,0],scale=[2,10,1],color=viz.RED)
avatar = viz.addAvatar('vcc_male2.cfg')
avatar.disable(viz.INTERSECTION)
avatar.state(2)
walk1 = vizact.walkTo([0,0,4.5],walkSpeed=2)
walk2 = vizact.walkTo([0,quad,9],walkSpeed=2)
walk3 = vizact.walkTo([0,quad2,13.55],walkSpeed=2)
walk = vizact.sequence([walk1,walk2,walk3])
avatar.runAction(walk)
view = viz.addView()
view.setPosition([-20,5,9])
view.setEuler([90,15,0])
window = viz.addWindow(view=view)
window.setSize([.4,.4])
window.setPosition([0,1])
Thank you Jeff for the previous programs.. Can the avatar also be made to climb stairs which is vertical? . The above programs work well for stairs which is inclined.. but i am not sure how to do it for stairs which is vertical
| Thread Tools | |
| problem with avatar climp a ramp | befl0 | Vizard | 14 | 07-30-2014 02:28 PM |
| .osg biped avatar problem | alvinadi | Vizard | 3 | 12-20-2011 10:29 AM |
| Avatar speaking problem | Uttama_vizard | Vizard | 4 | 03-23-2009 11:29 AM |
| Problem with letting an avatar face towards another avatar | ghazanfar | Vizard | 2 | 03-21-2007 02:30 AM |
| making a talking and imitating avatar | marc van gaal | Vizard | 9 | 10-20-2006 04:28 AM |
