Old 11-25-2014, 09:08 AM
You can add textures through the uniforms attribute of the effect class within the _createUniforms method. Here is a simple example:
class WarpEffect(vizfx.postprocess.BaseShaderEffect):
	def _getFragmentCode(self):
		return """
		uniform sampler2D vizpp_InputTex;
		uniform sampler2D redTex;
		uniform sampler2D blueTex;
		uniform sampler2D greenTex;
		void main()
			vec2 uv = gl_TexCoord[0].st;
			vec4 color = vec4(1.0);
			color.r = texture2D(vizpp_InputTex, texture2D(redTex, uv).rg).r;
			color.g = texture2D(vizpp_InputTex, texture2D(greenTex, uv).rg).g;
			color.b = texture2D(vizpp_InputTex, texture2D(blueTex, uv).rg).b;
			gl_FragColor = color;
	def _createUniforms(self):
		# Create texture objects
		redTex = viz.addTexture(...)
		greenTex = viz.addTexture(...)
		blueTex = viz.addTexture(...)
		# Apply textures to effect (automatically assigns uniform IDs)
		self.uniforms.addTexture('redTex', redTex)
		self.uniforms.addTexture('greenTex', greenTex)
		self.uniforms.addTexture('blueTex', blueTex)
Have a look at the Post-Process basics page in the documentation for more info:
http://docs.worldviz.com/vizard/postprocess_basics.htm
Texture Coordinate Generation (TexGen) using Shader goro Vizard 1 05-31-2013 02:44 AM
Avatar texture swaping sleiN13 Vizard 5 06-24-2011 01:48 AM
