Old 11-17-2014, 07:07 AM
yudhidayak yudhidayak is offline
Non skeletal based animation 3ds max export to vizard
Hi all,
Can I use 3ds max non-skeletal animation for Vizard?
If yes, what format should I use to exported to Vizard?
Is there any example of py file?
Apologies, if this topic has been discussed, could someone give me the link?
Thank you,
Yudhi
Old 11-17-2014, 06:30 PM
What type of animation are you trying to create?
Old 07-31-2015, 02:58 AM
vvgtom vvgtom is offline
Registered User
hi all,
i'm new in vizard i'm also interested in "Non skeletal based animation 3ds max export to vizard". what's the best way to export the animation from 3ds max to vizard ?
very simple animation "opening an elevetor doors".
Old 08-03-2015, 08:24 AM
Erikvdb Erikvdb is offline
If you want the doors to open in a linear fashion, you could easily just export the doors as separate objects and apply a vizact.moveTo.
Here's a snippet of code I used for a recent project:
obj_door = viz.add('door.osgb',viz.WORLD,1)
def onDoorOpen():
    open = vizact.moveTo([1.5,0,0],time=0.9)
    obj_door.addAction(open)
3ds max, animation, non-skeletal
Clarification on CAL3D Avatar Animation in Vizard shivanangel Vizard 2 11-22-2010 08:16 AM
2d text placing to max animation in vizard kasdeja Vizard 2 07-07-2009 02:34 PM
Export from 3Ds Max to Vizard pattie Vizard 5 08-26-2006 12:20 PM
