Hi Jeff,
Thanks for the reply. I will try your suggestions after lunch Although I have tried using vizconnect, the problem I seem to be having is that Vizard doesn't recognize the two gloves separately. For example, I connect the right hand on it's own and the fingers move as mine move. I connect the left hand on it's own and the fingers move as mine move. I connect both together and depending on the last port defined both hands move together. I don't even change the USB Ports that were defined for the individual gloves, and if I use the tutorial for the 5DT glove then they will move separately. |
Hey, got it working!! Played about with the setup file and the information you gave me. In the end I just needed to define the ports and add the 5dt file outside of the createcomposite, I was just defining the ports.
Although it'd be nice to do the same on the vizconnect, but it's not a major concern! |
Try adding two 5dt data glove inputs in Vizconnect and save the configuration file. It's fine if only one shows a connection at this time. Close down Vizconnect and open the config file in the Vizard GUI and find the initInputs section. You'll see code for data_glove and data_glove2. In the data_glove2 section change:
__main__.PORT_5DT_USB = 0 Code:
__main__.PORT_5DT_USB = 1 |
Hey Jeff, Thanks I got it working!!
Ok back to having the same/similar problem.....
So gloves work perfect on the vizsetup file. To create my virtual world I use viztracker, which then uses vizsetup.... without changing any thing if i run the script...it won't connect to the gloves ** ERROR: Failed to connect to 5DT glove on COM1 Then if I put the port definitions and glove additions into the create composite command in vizsetup, same error ** ERROR: Failed to connect to 5DT glove on COM1 So now i have tried defining the ports and adding the gloves in the main script, but for some reason it has went back to reading only one glove for both hands |
| Thread Tools | |
| animate an object using 5dt data glove 5 ultra | agrima | Vizard | 3 | 07-01-2014 11:17 AM |
| intersense with 5DT glove | sjp | Vizard | 2 | 04-06-2009 07:22 AM |
| data glove navigation | arielasso | Vizard | 6 | 10-24-2007 02:15 PM |
| Use of 5DT Ultra left handed glove | pattie | Vizard | 1 | 08-26-2006 12:59 PM |
| 5DT Data Glove 5 Ultra Problem | bjgold | Vizard | 1 | 08-08-2006 04:08 PM |
