Old 09-04-2014, 02:05 PM
Melody Melody is offline
How to get real time position of a object which is connected to a haptic device
How to get real time position of a object which is connected to a haptic device?
My haptic device is phantom omni
I tried to print it out, it shows [0,0,0] all the time.
I need to read the real time position and then apply different functions based on different positions.
Old 09-08-2014, 02:27 PM
Do you get changing positions with the following code?
sensable = viz.add('sensable.dle')
device = sensable.addHapticDevice()
def printPosition():
	print device.getPosition()
vizact.ontimer(0,printPosition)
Old 09-11-2014, 09:23 AM
Thanks Jeff.
May I ask how can I get the real-time spring force I applied?
I tried <effect>.getMagnitude(). But what I get is a constant I set in addSpringEffect.
<device>.addSpringEffect( gain=None
,magnitude=None
,position=None
,referenceFrame=None )
Position here represents the effect position, right?
And what is the relationship between magnitude and spring force? In F = k(P-X), magnitude is the max spring force?
Old 09-11-2014, 02:16 PM
After you've defined and enabled the spring effect you could create your own function that returns the spring effect force based on F = k(P - X). Something like the following:
import vizmat
def getSpringForce():
	#get effect position and gain.
	P = springEffect.getPosition()
	k = springEffect.getGain()
	#get haptic device position
	X = device.getPosition()
	#return force
	return k * vizmat.Distance(P,X)
Yes, the position value you pass in when you define the spring effect is the effect position.
The magnitude of the effect force is capped at the magnitude value you define.
Old 09-15-2014, 02:35 PM
Thank you so much!!!
Real time collision and object navigation sunil.nair Vizard 11 10-04-2013 08:10 PM
how to hide 3D virtual object behind real object? Darkmax Vizard 3 05-29-2012 09:39 AM
Time - seconds are longer than real seconds clowenth Vizard 6 05-19-2010 09:14 AM
Can you link the position of a tracker to the orientation of an object? michaelrepucci Vizard 1 09-19-2008 10:23 AM
