Old 08-18-2014, 04:24 AM
johnallen johnallen is offline
force screen refresh/update?
I have
gScreenTextObj = viz.addText3D('',parent=viz.SCREEN, pos=( 0, 0, 0 ) )
and then later in a function that was called following a key press using vizact.onkeydown()
gScreenTextObj.message = "asdf"
Is there anyway I can force the screen update to take place (displaying the new text 'asdf')? At present it waits until the function ends and flow returns to the main loop.
thanks,
John
Old 08-18-2014, 02:28 PM
Can you post example code that reproduces the issue?
Old 08-19-2014, 01:49 AM
pressing '1' displays a message, pressing '2' clears it, however it blocks waiting for the keyboard input on the viz.input() call.
i would like to flush the screen update before blocking for the keyboard input if possible.
John
import viz, vizconnect, vizact, vizinput, viztask
viz.setMultiSample(4)
gScreenTextObj = None
def keyPressed_1():
    global gScreenTextObj
    gScreenTextObj.message("1 pressed")
def keyPressed_2():
    gScreenTextObj.message("") # try to clear the message
    gCurrentPID = int( vizinput.input("Enter ID : "))
    gGAB = vizinput.choose( "Gender: ", ['Male', 'Female'] )
def exitExperiment():
    viz.quit()
def vizconn_kbd_mouse():
	vizconnect.go('vizconnect_kbd_mouse_monitor.py')
def experiment():
    global gTracker, gScreenTextObj
    vizconn_kbd_mouse()
    gTracker = vizconnect.getTracker('mouse_and_keyboard_walking')
    room = viz.add('room4.osgb')
    vizact.onkeydown('x', exitExperiment )
    vizact.onkeydown('1', keyPressed_1 )
    vizact.onkeydown('2', keyPressed_2 )
    gScreenTextObj = viz.addText3D('',parent=viz.SCREEN, pos=( 0, 0, 0 ) ) #write on screen messages here
# We've defined all our functions, now lets start our experiment!
viztask.schedule(experiment)
Old 08-19-2014, 07:02 AM
roobert roobert is offline
Send a message via Skype™ to roobert
I had the same problem, I solve it by starting the message variable in this way
#starting variable
gScreenTextObj = vizinfo.add( "" )
#change the valor
def keyPressed_1():
gScreenTextObj.message('1 pressed')
Vizard exits full screen after 30 seconds derek Vizard 3 08-21-2014 12:02 PM
Displaying screen text in 3D (Oculus Rift) pjayaram Vizard 2 05-27-2014 08:06 PM
Screen Size and Scaling javadi Vizard 2 04-02-2013 05:56 PM
Attach a TexQuad to pit.osgb screen Ducky Vizard 1 01-17-2013 02:57 PM
position of html-file on screen active_world Vizard 1 05-16-2008 07:24 PM
