Old 08-11-2014, 12:01 PM
JB_HP_Viz JB_HP_Viz is offline
Polhemus FasTrak Error Message
I get the following Error message in Vizard 5 Beta 4 when I try to connect a Polhemus FasTrak via USB
** ERROR: Failed to connect to a FasTrak: S : Device not found
** ERROR: Failed to create extension sensor with polhemus.dle
I tested the same Polhemus FasTrak via USB under Vizard 4 and it looks to work fine:
polhemus.dle Polhemus Extenstion
1 station(s) detected
** NOTIFY: Connected to Fastrak over USB Connection
I was able to connect a Polhemus Patriot correctly using Vizard 5 Beta 4
Has anyone tested a Polhemus FasTrak via USB with Vizard 5 Beta 4?
Any idea what the issue might be?
Thank you
John
Old 08-11-2014, 12:08 PM
Are you running 32-bit or 64-bit Vizard 5?
Old 08-12-2014, 03:07 AM
64 bit version
Old 08-12-2014, 12:05 PM
The 64-bit version uses a different API to connect to the FasTrak, since the original API only supports 32-bit. So there may be a bug in their new API. I've tested a USB FasTrak with 64-bit Vizard here, and it connects fine.
Are you able to connect to the FasTrak using the Polhemus PiMgr application? You might need to install the new USB drivers for it to work with the new API.
Old 08-15-2014, 09:32 AM
Looks like the FasTrak was using the 32 bit driver instead of the 64 bit driver. It looks like the 64 bit drivers are loaded on my computer, so I will see why it wasn't using the 64 bit driver.
I checked out my Patriot tracker and it is using the Patriot 64 bit driver and working correctly.
Thank you for the information, I should be able to get it working now that I know what to look for.
Polhemus Fastrak williamchappell Vizard 11 09-28-2013 08:49 AM
Polhemus Liberty Latus connecting error Yang Vizard 2 02-13-2013 11:52 AM
Integration of Polhemus fastrak transmitter data to Basic guy free rig in maya abhilash Vizard 0 04-15-2010 10:18 PM
Polhemus woes Enlil Vizard 2 09-02-2008 09:09 AM
fastrak Steve_HT Vizard 17 07-20-2007 09:51 AM
