Old 08-03-2014, 01:31 PM
Try creating a simple object in Max such as a box and verify the dimensions. The only thing you should need to do is export the model with Convert units set to Meters in the OSG exporter. Load the model in Inspector and the check the dimensions there. The status bar at the bottom shows the bounding box dimensions of the current selection. Does that work correctly for you?
3ds max, model, osgb, osgb export, scaling
Vizard automatically scaling image to an aspect ratio of 1:1 Frank Verberne Vizard 3 01-13-2014 08:48 AM
Scaling and Rotating in Vizard Vinicius Lima Vizard 1 07-25-2007 10:20 AM
vizard 2.5 compatability issue shai Vizard 3 08-10-2005 05:35 PM
